What I need to convert accdb file to exe file?
I want to convert numerous of accdb files to exe file. Is there a software to do the job? What software do I need to convert accdb file to exe file?
Hi, coshaun
An accdb file is a file which has the database in Office format, but an .exe file is a file to execute. Do you want to change an accdb file to an .exe file for executing after double clicking the file?
If you want to import the accdb data into a database, you need to make some changes according to which database you are going to import to, for example, oracle or informix ,you need do the SQL file.
You can fix your problem. To convert ACCDB file, there are two ways.
Hi
You want to convert access database(.accdb) to Executable file(.exe). There are many tools available for database conversion to executable file. Executable file is also another way to secure and safe your database and its data. Here I am giving you the
Watch the video
And if you want know about the conversion. See below official link of conversion tools. More info:
http://www.cpap.com.br/orlando/DBtoEXEMore.asp
Thank You.
Notifications
