Davis Avon
20 points
Posted on - 09/17/2012
I am currently rebuilding the setup of my Spyware Blaster 3.0 application following the procedure to make inno file repack games. There is this procedure to create an uninstall icon in the Start Menu folder. I have this gif uninstall icon stored on my desktop, but somehow, the setup would not accept this. Can you suggest standard image size and format for this?
What image format allowed for icon to make inno file repack games?
I see that you are facing a problem when you try to create an icon. Some softwares that create icons can create them only using a few formats of the images. The common formats used are jpeg or png. You can either download a new software that accepts gif images or you can convert your gif image to jpeg. The second option is a much easier one so i suggest you to do that. Just follow the steps below:
Go to http://www.converthub.com/giftojpg.php and download the software.
Save the setup file on your desktop and install it on your computer.
Now run the application and select the image you want to convert.
Select the output format as jpeg and click convert.
Your gif image will be converted to jpeg and you can use it to create your icon.
