What is the importance of internet in school
Internet has been used by students to access materials which help them do their assignments. Moreover the internet has been used by school management to facilitate service delivery in that students and staff can do online registration and also view various documents such as fees statements. In more advanced institutions the internet has been used to teach students without necessarily attending classes, E-portal.
It let's you make the library beside to you and easy to access. Though It costs connection money to have a connection, it will help you search for important things you need and the important part is when you are at home and the library is far away from you, the importance of internet enters this part where you can find the answers to you problem and will help you even by means of tutorial. It will also help you communicate with people like your classmates when doing projects(which always happens to me) I suggest everybody must have internet connection. And also, It helps you remove stress by means of socializing and games. Just don't focus much on it.
