What is Infinite Monkeys used for?
Infinite Monkeys enable one to make apps for smart phones. It enables you to create apps that will be compatible whether for iOS or Android. It is basically a Mobile Apps builder.
The purpose is to bring the creation process of apps to more people even if you are not a trained applications or web developer. It claims to allow people to create apps within 20 minutes. Anybody who understands smart phones and how they work can use this to create their own app. If you have an app idea and it is not yet around, you can try creating it yourself.
Mnkabir,Â
Infinite monkeys is an online software by which you can make your own apps for iPhone, Android or HTML5. You can create your own app even if you are technically not so known to the app making process. The first app will be free and then you have to pay a nominal charge of $49.Â
When you open the page of Inifnite Monkey, you have to enter the title of the app which you wish to create. After that, you have to login through google , facebook or msn account. You need to update your infos, customize your themes and create a free app. Its a good software for those newcomers, who wish to explore the app building world.Â
