What is inside diskeeper 2012?
i have a problem with my pc,even though I'm using 4gb ddr2 memory and a 1 TB hard drive I find my pc so slow.Especially when im opening and saving file in spreadsheets. also in using a system that runs program located in different paths and location.My co worker ask me to defrag my pc but still my pc is too slow..how can i used diskeeper in this matter?
Answered By 5 points N/A #161430
Good Day Ellimac2603,
In this case, maybe your Hard Drive was penetrated by viruses that corrupts some important system files installed into your computer. Now, with the use the “HyperFast” feature included in Diskeeper 2012, your computer system running will be remain as fast as when you obtain it by optimizing the free space on your Hard Drive. HyperFast feature specifically gives solution these issues by intellectual and eliminating performance. In this technology,  with the IntelliWrite Technology encourages the more well-organized and more useful chronological writes to happen slightly than random rights.
HyperFast approaches standard with Diskeeper 12 Home, Server and Professional Editions.
I hope this information helps,
Mark Amna
