What is install manager app and what it does?
I got an Android phone. I’ve been wondering what is install manager app does? Please give me some ideas with this. Is it important or not? Please help. Thanks guys!
Hello,Â
Install Manager is an application which gives you a complete control over the applications you have in your android, it allows you to manage them, move them, install them in a particular location etc. Basically total management of the applications. Some of the paid install manager applications allow you to remove system apps if you don't need them, they also allow disabling and enabling a particular application.
As far as usability of this app is concerned, it completely depends on how much a mobile geek you are. If you like to have a lot of applications in your mobile and you remove and add new apps every day, it is a good tool. But if you generally don't install any application and are satisfied by those which came with the phone itself, then you have no use of this app.
I hope this answer clears your doubts.
