What is Interchangeable Lens Camera?
Nikon 1 J2 camera is being called Interchangeable Lens Camera.
Why is it called like this?
What is additional facilities in it?
Hi Amy,
The interchangeable camera is the camera which comes with interchangeable lens unlike other digital camera that come with a single lens. These cameras are equipped with relatively large sensors. When a picture is taken by the camera, the light hits the imaging surface instead of the mirror. The picture quality of interchangeable Lens Camera is as good as a DSLR. The photo effects are just amazing.
Hi Amy,
Recently, there’s a new release to Nikon’s I J series. The pre-installed 10-30 mm lens has a switch on the lens barrel. As it is called a camera with interchangeable lens, Nikon releases an 11-27.5 mm lens, compact yet equivalent to a 30-70 mm lens. It is also created to smaller and lighter than normal lenses.
Check the image below to better understand the functions of this new camera release from Nikon; and also the lenses that can be used with it.
