What is IP address and how to find IP
IP stand for Internet Protocol address and IP Address can be defined as unique name for a computer on the network.
Normal IP address includes collection of numbers and these numbers can be from 0 to 255. (EX: 172.16.50.60)
Method for find IP address
Thank You
John Major.
Hi John Paul281112,
Hi John paul29112,
IP address is abbreviated as Internet Protocol address it is a numerical label assigned to each device which is connected to a Network that uses the Internet Protocol for communication. It is used to identify the device and also it is the address given to that device. There are two versions of IP [Internet Protocol] are in use IPv4 and IPv6. IPv4 is a 32-bit Number and IPv6 is 128 bits. Due to the Enormous growth in Internet IPv6 was introduced.
To find out the IP address of your system:
Open Command Prompt and type ipconfig and click enter. You can get the ipaddress of your system.
Thank you,
Clotildec barbara
Hi John,
Thanks for sharing your question here.
You want to know about IP Address.
IP Address is an acronym of Internet Protocol. So it is an address which recognizes our computer on internet.
Or IP is the address of our computer on the internet.
IP address consists on 12 Characters and 3 Dots.
like 192.168.100.120
You can check IP address by two methods. First way is to go to Command prompt.
Type CMD in Run and press enter then type ipconfig.
Your IP address will be shown to you. But it is not public IP it is the IP which your ISP has assigned you by DHCP.
If you want to check your public IP then type "What is My IP" or "IP Address" in google.
It will show you your public IP address
Thanks
Hi John Paul281112,
