What is IPS monitor and LED/LCD monitor and difference?
Hi!
I am thinking of buying Asus MX299Q 29" LED AH IPS Monitor. What are the specifications of this monitor? Why is it too much price endowed in this monitor? What are the benefits of this monitor from the others? What do you mean by IPS? What is the edge of this so called IPS monitor rather than buying LED or LCD monitor? What are the best side and downside of buying this monitor? Should I still consider buying LED monitor because it’s cheap or looking in to this? Please guide me.
Thank you!
Answered By 0 points N/A #165987
Hello Young!
IPS means In-Plane Switching. This is used in modern LCD and LED monitor and or sets. It eliminates the poor reception and or provides better picture quality for latest tv. This also used to eliminate angle viewing that degrades the picture quality of a monitor. The price range is from $424 to $525.
Specifications
1.    Aspect ratio 21:9 and screen resolution of 2560 x 1080.
2.    High picture quality and less picture distinction.
3.    Super thin panels
4.    Splendid video intelligence technology
5.    Speakers
Ports available
1.    PC Audio Input
2.    HDMI
3.    3.5 mm mini jack
4.    HDMI/MHL, DisplayPort, Dual-link DVI-D
The best features of this monitor is that it is like panoramic because of its wide screen. You can do your work while watching movies. The price is expensive due to the features added like the speaker from Bang&Olufsen. The crystal display that is far from 16:9 aspect ratio and the thin panels. These are just a few features of this monitor
