What Is 0x8007025d 0x2000c Error?
Hello. I was trying to update my Windows 10 PC using a media creation tool; then the 0x8007025d 0x2000c error displayed saying the update failed. Please help me to solve the error. Thank you.
Hello, people. Many windows users are facing the error 0x8007025d 0x2000c while updating their Windows version using some media creation tool. We have listed a few solutions to resolve it; follow them.
Method 1:
Update the BIOS on your PC. Sometimes the older versions of BIOS also cause these errors, so check with OEM and maintain the latest BIOS versions.
Method 2:
Restart BITS
• Hold Windows key + R; it opens a run dialog box.
• Next, type “services.MSC” and hit ok.
• In the opened window, search for Background Intelligence Transfer Services, double click on it, and select its properties.
• Set Automatic(delayed) as your startup type and click on apply.
• Click on start and stop to stop and restart the BITS services.
• Click on Ok.
