My system used to work well until yesterday. Last night I tried to install a game and started the process, but after finding that it contains malware, I stopped it. Now when I am trying to open the system, it is showing error 0xc00000ba file download something like this.
What Is 0xc00000ba File Download?
The unfinished installation can be a reason for this. You can’t say it is the actual reason. Some other problems may also create this. You may shut down the system improperly or reluctantly in the last use. Remove the installation and check for the improvement. If it won’t work then uninstall any other newly installed services and try. Sometimes missing of 0xc00000ba file will also lead the error, so check for it and fix it if anything is needed. You can install special software which repairs it and restores its stability.
