What Is 3rd Hard Disk Error?
A) To fix this 3rd hard disk error, you will need to follow these steps:-
1. Put the Windows media in the DVD drive, and then start your PC.
2. Hit any key when asked.
3. Choose a language, a time, a currency, a keyboard, or an input method, and then press the Next button.
4. Hit the Repair your computer option and choose the operating system that you want to repair, and then hit the Next button.
5. Inside the System Recovery Options, click Command Prompt.
6. Write down Bootrec.exe, and then hit the Enter key. Bootrec supports the following commands:
/FixMbr
/FixBoot
/ScanOs
/RebuildBcd
Use these commands according to your PC condition.
B) To solve this 3rd hard disk error, you have to replace the hard disk inside your PC and reinstall the whole system, i.e., in the worst-case scenario.
