What Is A Required Privilege Is Not Held By The Client?
I was wondering that if you could clarify for me that what is a required privilege is not held by the client and how to fix it?
A) You face this error when you usually try to create a file inside your PC. To solve this “a required privilege is not held by the client” error, you will need to follow these steps:-
1. Hit the Windows menu key and the R key altogether, write down Regedit inside it, and then smash the Enter button and open up the Registry Editor.
2. Now, go to this location- HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
3. On your right-hand side, locate a DWORD (32-bit) Value called EnableLUA.
4. Now, change its value to 0 and ensure that you can create a new file or not.
B) To fix this “a required privilege is not held by client” error, you will need to follow these steps:-
1. Inside the Taskbar, search box area write-down “secpol. msc” and press the Enter button.
2. Now, go to the Local Policies > Security Options. And find User Account Control: Run all administrators in the Admin Approval Mode option on your right-hand side.
3. By default, it is in Enabled option mode. You will need to select the Disabled option and save your changes.
