What Is Disk Probe Windows 7?
Can someone please explain what disk probe Windows 7 is? I do not know this feature of Windows, but I want to understand and use it. Help will be appreciated.
Thanks for writing to us. I will briefly explain to you what disk probe Windows seven exactly is. On computers disk probe is a sector editor for drives on computers which are running on Windows XP and Windows Server 2003. Any user who has Administrator rights can use the feature of disk probe to edit, save, or copy data on HDDs (hard disk drive) that are not accessible in any other way.
This tool can also help you in preparing the disk for disk-based problems as it saves critical disk structures before any serious problem(s) arise. The documentation and disk structure preservation, like MBR or boot sector, ensures a fallback in case of disk corruption. It can be used to resolve problems that one may encounter while working on the computer(s). With it, one can also edit and repair disk sectors on a bit by bit basis if any corruption occurs.One can also use it to replace MBR or repairing the damaged partition information.
