What Is Error 0x80070571 Windows 7
What does the error 0x80070571 mean? I have never seen this error before. After completing an automatic system update, when I restarted my computer, I started getting this error again and again. How to fix this?
This error code only occurs when something is broken with the system. This can happen when your computer is infected with a virus or malware. This can also occur when there is some program that is incompletely installed or was not uninstalled properly.
There are two things that you can try. First, disable your antivirus and try to install the updates then. If this doesn’t work, restart your computer and log in as administrator. Then open System Tools and go to System Restore. Then, select the option that reads something like this, restores my system to a previous time. Restart your computer once again and the problem should be gone.
