What Is Error 0xc00000034
What is error 0xc00000034, and is this a blue screen error? Why is the error appearing in my PC, and how can I fix this error?
Yes, this is a blue screen error, and it is an error related to the boot configuration data file. These type of error appears in any windows platform and are very difficult to solve. If your boot configuration file is misplaced or damaged, then this type of error might occur. Following are the steps to fix this error
After you successfully place installation media you can start your computer, it will begin the booting and show a message like press any key. After that, you must click on repair your computer and troubleshoot. Choose automatic repair this will repair this error automatically.
Here you have to copy the identical steps as earlier but instead of clicking on automatic repair click on command prompt. In there you can type your commands and then restart your computer.
