What Is Error 404 Not Found And How To Resolve It?
While accessing a web page, I came across an error ‘Error 404 Page Not Found’. I am unable to access that webpage. Why am I facing this error code and what is Error 404 Not Found?
Error code 404-Page Not Found is an HTTP status code which means that the page or URL you are willing to access does not exist on the server it used to be. This error mostly means that the page doesn’t exist anymore.
There could be the following reasons:
• The page is removed from the web or server.
• The URL or webpage is under maintenance.
There is no solution for this error because it is not an error exactly. It’s a status code.
The webpage may have changed its URL. You can try to find its new URL.
