I run a regular scan for the virus in my system. Last time I got an error and I removed the virus from the system. When I am trying to log in to the system, it is giving a warning saying error code 0x80090006. How to solve this error code?
What Is Error Code 0x80090006?
The error occurs due to system files failure. Due to some corrupted files, the windows are unable to check the license. You once try by booting in safe mode. The antivirus you used may be deleted the rsaenh.dll file from System32. Through the command prompt, replace the folder with an extra copy through administrator mode. If it is missing even there, you can get it from online or friends. If this won’t work, then restore your computer to some other configuration. You can also use automatic error correction software from online to solve this.
