What Is Error Code 0xc00d1b83?
I am using a system for the past ten years. There are so many files in the system and are running out of space. So I thought of converting WAV files into WMA files. I downloaded the Windows Media Encoder. Whenever I try to transform it is showing error code couldn’t find sufficient file error 0xc00d1b83.
Answered By 0 points N/A #322483
The error should be solved as soon as possible as it may lead to many other errors in the system. The error occurs if you have ULEAD software installed. If it is there then uninstall it. If you don’t have that software, then partial deletion or corruption of files may be leading to this error. To solve this, restore your system to the previous version by using admin mode. You may also try by downloading error fixing software application and restarting the system. If this won’t help you, then you can convert them by using a CD.
