What Is Exception Processing Message 0xc0000005 Fix
Whenever I open certain programs on my computer, I get an exception processing message 0xc0000005 and then the program simply just not open. I have never seen anything like this. Is this a common error? Is there a solution?
Answered By 0 points N/A #322233
Believe me or not, this error is one of the most common errors in all versions of Windows. The error code indicates that it is a process error. This means that due to a problem, Windows operating system is simply not able to complete whatever process you started. Therefore, once this error occurs you are unable to run the program that you want to.
Causes of this error include corrupt files, virus or malware infection and many more. If you are not a power user, I suggest you get help from tech support. If that is not the case then you can try to disable DEP (Data Execution Prevention), disable proxy, or change the Windows Explorer settings.
