What is Exchange 2010 RAM requirements?
I will install Exchange 2010 server. I know it can have different roles. I want to know the minimum Exchange 2010 RAM requirements according to different server roles.
Here is the minimum Exchange 2010 RAM requirements according to different server roles –
1 – If you want to use the Exchange server as Edge Transport or Hub Transport or Client Access or Unified Messaging or Mailbox, you need a minimum RAM of 4 GB.
2 – If you want to use the Exchange server as a combination of Client Access and Hub Transport, you need a minimum RAM of 4 GB.
3 – If you want to use the Exchange server as a combination of multiple roles, you need a minimum RAM of 8 GB.
