fernerich
10 points
Posted on - 08/06/2019
What is meant by error 0x800c0005 Xbox one? What are the steps to fix this error?
What Is Meant By Error 0x800c0005 Xbox One?
This error occurs when you play music or video on the Xbox One. The central reason for this mistake is that when your Xbox one gets disconnected from services. Due to failure connectivity and incompatible type of NAT, also this error arises. There are a few steps which will help in fixing this error,
- Open Xbox and go to settings. In settings, click on network, and in that choose NAT.
- In NAT type it will show what current NAT you are using.
- The NAT type should be set correctly to Open NAT, and this will stop error 0x800c0005.
There are various NAT types such as open NAT, Moderate NAT, and Strict NAT If the NAT type is strict or moderate, then change it to open, and this will resolve the error.
