What Is Mfc71 Dll How To Remove Error
While launching a game, I got the error the program cannot be started because mfc71 dll is missing. What is this file used for? How do I remove this error? Do I need to call tech support or can I do it myself?
Mfc71.dll is a DLL (Dynamic Link Library) file associated with Microsoft.NET, and many programs require this file in order to run on Windows. Errors related to mfc71.dll can occur due to faulty installation of a program, missing/corrupt file, and so on.
No. You do not need to call tech support. Errors related to DLL files are very common and usually have very simple solutions. To remove this error, all you need to do is download the missing file from the internet and place it in the System folder of your computer. Restart, and the problem will be gone.
Notifications
