What Is Microsoft Office Access 2003?
What is the use of Microsoft Office Access 2003 in the system and how to use it? As I got it in my office package, I want to know why it is required.
Microsoft Access is a database management system which is introduced by Microsoft in order to combine relational Microsoft database engine with graphical user interface. It is used for the development of application software by software engineers, architects, etc. Unlike other products, it does not create any mess and is compatible with the windows. It is supported by visual basic applications which means that it is an object-based programming software or language.
If you don’t have Microsoft office access 2003 in your system, then you can quickly download it from the Microsoft’s official website or any other websites of your choice. Same explanation stands for Microsoft office access 2007 and 2010. The difference lies in the runtime of the software, addition of new features and easy to use application added features.
Microsoft Access or Microsoft Office Access is a pseudo-relational database engine from Microsoft. It is a DBMS or database management system that merges the relational Microsoft Jet Database Engine with a GUI or graphical user interface and software development tools. Microsoft Office Access is part of the Microsoft Office suite of applications included in the Professional and higher editions or it can also be sold separately.
Microsoft Office Access is used for both small and huge database deployments. The Microsoft Jet Database Engine supports most database features like referential integrity, row-level locking, and multi-user support with up to 255 simultaneous user connections. Microsoft Office Access stores its data in its own format based on the Jet Database Engine. It also allows you to import or link directly to data stored in other databases and applications.
