What Is Microsoft Office Error 25004?
I was trying installing Microsoft office 2013 and my system encountered error 25004. I want to know how to get rid of Microsoft office error 25004?
Microsoft Office error 25004 occurs if you have already installed Office 2013. Either it was not installed properly earlier or not uninstalled properly. This happens mainly due to the use of same product key. As you have installed earlier, the system will not accept the same product key used earlier.
To resolve this issue, install the earlier installed Microsoft Office 2013 from your system and then reinstall again. Then the error won’t occur.
Go to Start > control panel > uninstall > select the program to uninstall.
You may encounter error “25004” when you install Microsoft Office 2013 on a computer that already has a version of Microsoft Office 2013 installed. To fix the problem, simply uninstall the existing version of Microsoft Office and then install your edition of Microsoft Office 2013 again. Click “Start,” “Control Panel,” “Programs,” and then “Programs and Features.” Scroll down and select Microsoft Office 2013 and then click “Uninstall.”
Follow the instructions to remove the entire Microsoft Office suite and then restart the computer. After booting, install Microsoft Office 2013, the one you are trying to install and see if it works. You cannot install two different editions of Microsoft Office if they are just the same version.
