I have a Windows 8 PC, and I keep getting this error MSVCR71 DLL missing. I do not know much about computers, so if someone can tell me what this error is and why it is occurring, and what is this DLL file used for it would be a great help.
What Is MSVCR71 DLL And Errors Associated With It?
MSVCR71 DLL file is an important DLL file used by both Microsoft application as well as non-Microsoft applications. This file helps other applications to control and display items, such as dropdown menus, Mouse events, buttons, and scrollbars. So it helps in achieving a proper user interface. This file is present in the directory folder of C drive.
The error that you have said is a common one that occurs when this file is accidentally deleted or when there is a Malware or a Virus. In case of accidental deletion, you can check for this file in the Recycle bin. Suppose, if this file is deleted permanently, then you can try the free recovery software to get it back. You can also download this file from AddictiveTips, an authenticated website. Run a Malware scan, if it was not accidental deletion. Update the drivers for hardware devices if, you met with this error while playing a game.
Sometimes, your computer will have a backup copy of this DLL file. It is not just your system that will have a copy of this file but also all the other programs that use it. In the error message that you get, it will show you the folder from where this file is missing. So, search for the copy in other folders.
