What Is Ncs2prov.exe
Ncs2prov.exe is a software component of Intel PROSet for Device manager by Intel Corporation.
This component is also associated with the Ethernet card drivers in computer. This file is designed through the Web-based Enterprise management standards using Windows Management Instrumentation. A WMI service call requesting Device manager causes Ncs2prov.exe to automatically start and send all the Information, also stops after this process. This file usually resides in C:\ProgramFiles\Intel\NCS2\WMIProv. If found other than this path, then it’s possibly a malware that you must delete.
The issue involving should not occur if you constantly clean your PC, to make it malware-free. If the issue somehow makes its way into your PC because of this file, then contact Customer service.
Notifications
