Abrianna
60 points
Posted on - 07/20/2019
I use Kaspersky Antivirus for my laptop. I suddenly started getting prremote dll kaspersky error on my desktop. I ignored the error when it first came up thinking that it will fix itself when I start the computer the next time. This did not happen, and the problem persists. How do I remove this error?
What Is Prremote Dll Kaspersky Error How To Remove It
Dll files are Dynamic Link Library files that are usually present outside the software that they come with because these files are often shared between programs. Dll errors occur when a certain dll file is either missing or has been corrupted.
In this case, the prremote dll kaspersky error means that the prremote.dll file, which is related to KasperSky Antivirus is either missing or has been corrupted. To remove this error, you will have to find the missing dll file, download it, and place it in the correct directory. There are many websites that allow you to download different dll files. However, it is advised that you only download files on the internet from websites that you trust to avoid getting infected with viruses and malware.
