What Is Pwmtr64v Dll Error Lenovo
I own a Lenovo laptop. It used to work fine until I ran into a rather irritating problem. Everytime I restart the system or sometimes when I boot the system, the system throws a pwmtr64v dll error at me. This has become really annoying. What is the solution to this problem?
Answered By 10 points N/A #321747
In the specific case of Lenovo’s computers, this problem is actually found to be associated with a driver. Everytime you restart your system you get the said error along with the pwmtr64v.dll file missing message.
In most of the dll file missing errors, the error can be removed by downloading the missing or corrupt dll file and place it in the appropriate folder. But in your case, you need to update one of your drivers. In particular, you need to update the Lenovo Power Manager from the device manager.
Go to the Device Manager and expand System Devices. Select Lenovo Power Manager and open properties. Select driver and click on Update Driver. Once the update is complete, restart your computer. Voila! Your problem is now solved.
