What Is Sqlsrv32.dll Download Useful For?
What is sqlsrv32.dll, and what is it used for? What are the various versions of sqlsrv32.dll download? What are the possible solutions which can fix this type of error?
It is developed by Microsoft; it usually contains a set of procedures and functions of drivers which are applied in your system. Sqlsrv32.dll is also sometimes known as SQL Server ODBC Driver. It is used to check that the windows program operates properly. Various versions of sqlsrv32.dll download are 6.3.9600.16384, 6.2.9200.16384, 6.1.7601.17514 all this are for a 32-bit system. Other versions are available for a 64-bit system. Sometimes your computer may also get an sqlsrv32.dll missing error so to avoid that you need to place your DLL file in the machine directly.
Some of the very basic ways to ways sqlsrv32 errors are that you need to reinstall the application, update the app to its newest version, and clean your windows registry.
