What Is The Best Dpi For Scanning Photos
One of the major questions that strike the head while getting a scan is what is the best dpi for scanning photos? Need to know more about this dpi?
Once you know, what are the details that you need from the image for cropping purpose, its resolution that is mostly in pixel size and the size of the file, it is very easy to obtain the required outcome. Maybe in the starting of few scans, this may confuse you, and you will need a guidance to achieve this soon, this can easily be excelled by some understanding of its logic. Then people will ask you, what is the best dpi for scanning photos? It must be difficult to go on changing the dimensions of photos in case if you are dealing with hundreds of photocopies. Just set some dimensions that would become an easy all time reference.
