What Is The Cause Of The 0x80072ee2 Office Error?
Hello, people. I tried to activate Microsoft Office 365 on my PC, and I got the 0x80072ee2 office error. Please give a solution to fix the activation error. Thank you.
Hello. The 0x80072ee2 office activation error caused because of the improper installation and proxy server, etc. Follow the below methods to fix it.
Method 1:
Repair MS Office
• Go to the Windows search and search for a control panel and open it.
• Select uninstall the program.
• Navigate to MS Office 365 and click on it. Go to the change tab and click on quick repair.
• If this method doesn’t solve the issue, then uninstall and install it again.
Method 2:
Date and Time settings.
• In the Windows search box, enter time & date settings and hit enter.
• Next, check if the settings of set time & time zone automatically are enabled, if not enable them.
• Restart your system and try installing or updating your Windows version.
