What Is The Cause Of The 0x800c0133 Outlook Error?
Hello, experts. Whenever I sign in to Outlook Express and start viewing the messages, then suddenly the 0x800c0133 Outlook error pops up. Please help me with the solution. Thank you.
Hello. The 0x800c0133 Outlook error occurs because of corrupted registries of the Windows, or the size of the file or the corrupted system files also cause the error. Follow the below-mentioned methods to resolve the 0x800c0133 Outlook error.
Method 1:
Windows registry.
• Hold Windows key + R; it opens a run dialog box.
• Then type Run and hit enter.
• Next, go to the below-mentioned path.
HKEY_LOCAL_MACHINE_Software/Software/Microsoft/Windows/Current Version/run
• Next, select the corrupted files and delete them.
• Restart your PC.
Method 2:
• Open Outlook Express.
• Go to local folders and create a new temporary folder and move all the emails to the new folder.
• Select the browse button and select the location for a DBX file.
• Next, choose options in the tools menu.
• Go to the maintenance and select the store folder.
• In the next dialog box, go to the DBX file location.
• Delete the DBX file and reopen the outlook.
• And move all the files into a new folder from the previous temporary folder.
