What Is The Error 3194 ITunes Fix?
Please help me with the error 3194 iTunes fix. I have iTunes installed on my Windows 10 PC. I am unable to communicate with the Apple server. Please help. I don’t have a proxy network, and I turned off my firewall too.
Answered By 0 points N/A #344255
There is an error 3194 iTunes fix that requires manipulating the host files.
a. Close all the running apps on your PC.
b. Open C:\windows\system32\drivers\etc\hosts.
c. You have to find – 74.208.105.171 gs.apple.com.
d. Add a # before the line. Newline – # 74.208.105.171 gs.apple.com.
e. Press Ctrl + S to save the changes.
f. Restart your device.
Method 2
You should try to connect your device to some other computer with a different internet connection.
Method 3
a. Back up your iPhone data.
b. Enable the “Find my Phone” option.
c. Log in to iCloud.
d. Open Find my Phone in iCloud.
e. Select your phone.
f. Click on All devices.
g. Select your device.
h. Click the Erase button.
i. Set up your iPhone, and restore the backup.
j. The error should disappear.
