What Is The Method To Resolve The 0x800700b7 Windows 10 Error?
Hello, I am getting the 0x800700b7 Windows 10 error while trying to perform a restore on my Windows PC. Suggest a solution to resolve the error. Thank you.
Hello. Usually, the 0x800700b7 Windows 10 error occurs while performing system restores in Windows 10 PC. This error message occurs due to the failed software installations and their invalid registry keys. Follow the below-mentioned methods to resolve the issue.
Method 1:
Installing pending updates.
• Thoroughly check for incomplete updates on your system and update all the pending updates. Because pending installations and updates will leave invalid registry keys in the system software, so complete the pending ones.
Method 2:
Disk Utility check.
• Go to This PC, select the C: drive, right-click on it, and open its properties.
• Navigate to tools and click on the check icon.
• Click on scan drive, and allow the scan to complete.
• Restart your PC.
Notifications
