What Is The Ms Sql Server Report Builder Latest Version In Market.
Hey, how can I us ms sql server report builder on my windows system also states its features for the easy understanding for the same . Thank you in advance.
Hello, the ms sql server report builder is used to design the reports in the report designer and report builder. And the present version for the same is v3.0. It consists of 2 environments authority like to create the report files, report data and the layouts too. It is a part of windows SQL Server. It also includes SSAS SSIS types of services in it. The key features for the same are as follows :
• Table designer
• It consist of database diagrams
• Contains index manager
• Does unit testing
