What Is The Msorcl32 Dll File How To Fix
I am looking to connect to Oracle from MS Access. When I try to do so, the system just gives me the error msorcl32 dll missing. I am not very computer savvy and cannot go past it. How do I solve this error? Can I do it myself or do I need to call service?
Answered By 50 points N/A #322048
The dll file that is causing you trouble is required by the Oracle ODBC driver. DLL stands for Dynamic Link Libraries. DLL files are shared files that are used by multiple programs to run their services. This is why dll files are not associated with the program that installed them initially.
Dll errors occur due to missing or corrupt dll files. There is an easy fix. All you need to do is find this dll file on the internet, download it, and then place it in the required location on your system. Restart your computer after doing this and voila! The error is gone.
