What Is The Solution For Br0253e Errno 13 Permission Denied?
I was trying to restore a database, and suddenly the oracle analyzer stopped running, and I got the message that br0253e errno 13 permission denied what is the solution of this and how can I fix this problem?
Answered By 0 points N/A #320099
Error br025e errno 13: permission denied means that this error is related to user permission or the owner of the system. To fix this issue, you need to check the acceptance of the following path: /oracle/SID/sapbackup and use the following command to check verification.
Command: #ls -ld /oracle/SID/sapbackup
You can also try entering: /oracle/SRD/sapbackup/backSRD.log this can also help you to resolve your error. And will tell you that you have given correct permission or not. If not, you can do the required modifications to fix the error.
