I have properly created a partition of 150 MB to store the system image of Windows 10. But when I am creating a System image, I am encountering a 0x80780119. I do not know the meaning of the error, and I am not able to solve it. Please help!
What Is The Solution For The 0x80780119 Error In Windows 10?
If you are sure that you have created a partition properly, then the partition may be filled with some junks. Let’s not go deep into the meaning, and jump to solutions.
Method 1
a. Open Command Prompt as admin.
b. Type fsutil usn queryjournal F: and press enter.
c. Type fsutil usn deletejournal /N /D F: and press enter.
d. Your problem should no longer exist.
Method 2
a. Right-click on the start menu.
b. Open Disk management.
c. Select System Reserved volume and right-click on it.
d. Click Next.
e. Set the size of the volume to a minimum of 5000 MB.
f. Save the changes.
g. Try to create a system image.
