What Is “the Stub Received Bad Data” Error?
This type of error usually occurs in windows 10. You might get an error code or a statement message stating the stub received bad data error. Closing the application and reopening it again might sometimes solve this error. It is just a pop up that will keep popping again and repeatedly until you find a solution for it. You can conduct easy, well-known steps to get rid of this error such as perform an SFC scan.
SFC scan is very powerful and has the capacity of repairing all the damaged files. It is an excellent solution for the stub received dangerous data error. Another solution you can try for is that by making sure you have the latest update of windows, if not install it. Cause maybe because of the older update of windows this kind of pop up message might receive.
