What Is The Use Of A Compressed Air Can For Laptop?
I have got a compressed air can as part of a service package for my laptop. Can someone explain what is the use of a compressed air can for laptop?
A compressed air can is extremely useful as it can help you clean dust from your computer. Dust can collect in your computer over a period of time and cause it to heat up. Overheating can really damage your computer and even clog the built in fans of the computer.
To use an air can, you need to open up your computer using screw drivers and then use the air can to spray and clean out the air. If you are not sure how to do it, kindly visit a service centre to get it done, do not attempt it yourself without adequate experience.
