What Is The Use Of Windows Remote Management Windows 7?
Windows Remote Management in Windows 7 is a command line-based organisation protocol. It depends on HTTP that allows through many corporate firewalls.
To enable Windows Remote Management,
• A user needs to manually perform it on the workstations and servers to manage remotely.
• Select Start Menu and go to “Run” command.
• Type “winrm quickconfig” in the command prompt and run.
• The system changes are going to take place.
• To establish a connection, add the computer to the trusted hosts list.
• Change the IP of the remote computer as “winrm set winrm/config/client @{TrustedHosts=”192.168.174.130”}.”
• Use the command “winrs –r: 192.168.174.130 –u:Taylor –p:Pa$$w0rd netstat” in the Windows Remote Shell Command.
• You need to substitute the values.
• Substitute 192.168.174.130 for the IP address of a machine with WinRM enabled.
• For the username of a local administrator on the remote machine “Taylor” is substitute.
• Substitute the word “Pa$$word” for the password and user account mentioned on the top.
• Substitute “Netsat” for command to run. Finish the program and Remote Management becomes activated.
