What Is The Use Of Windows Remote Server Administration Tools?
What are Administration Tools? What is the use of Windows Remote Server Administration tools? How can I download them?
Remote Administrator Tool on a computer allows its remote host computer to manage and control the Windows. It helps in operating a remote system and resolving its problem without touching the system.
To enable the Windows Remote Server Administration Tools,
• Click on Start Menu and then select Control Panel. Go to “Programs and features.”
• Click on “Turn Windows features on or off” tab which is visible to extreme left. (Windows Features dialog box will show).
• Select “Remote Server Administration Tools” option. (Activate all the option mentioned it).
• Under “Feature Administration Tools” enable all the options mentioned.
• Select “Active Directory certificate services Tools” under Role Administrator Tools. Activate the options. Select the options under “AD DS and AD LDS Tools.”
• Under “AD DS Tools” enable all the three options. Under “File Services Tools” activate all the options mentioned. Press the option “Ok.” (Microsoft Windows dialog box will open and Windows will start making changes).
• Now click on “Administrative Tools” under Control panel.
• Right-click on “Active directory users and computers” and click on “Pin to taskbar” option.
• “Active Directory Users and Computers” window will open. Click on “RDPclab.com” which is on extreme left to finish the process.
