When I tried to play Animal Crossing in my system online, I got this Wii error 50299. I visited the Nintendo website, and it’s just saying to configure my settings and channel. Then also this problem is not solved. What should I do know to get rid of this?
What Is Wii Error 50299?
Sometimes it may be due to internet connection also. So first, check the connection settings properly. Turn off the router for at least 30 seconds and make a new connection. If this won’t work, try with the other step. Go to the nintendo.com website, and on the home page, you will find a saying connect your Wii. Play the video and do the steps in order. It may or may not work. If nothing helps call to the service center.
