What Is Wii Error Code 201022?
I used to play Mario a lot. Due to space issues, I deleted it long back. Now when I am trying to install it again, it is showing the Wii error code 201022, and then the download gets failed. I downloaded it several times, but it is just repeating the same. What can I do now?
Answered By 0 points N/A #321034
It is the worst possible error. You can check your internet connection and try again after some time. It can also be an issue in your Nintendo hardware, etc. It may be because the Nintendo server is down for some time. Try to install it after some time or the next day. The issue may be due to heavy load today.  If nothing helps you, then you should call the Nintendo service center to troubleshoot your problems.
