What Is Wii Error Code 50300?
When I try to connect using my net I got error 86420. Then I followed the steps in the Nintendo video to manually set the wifi. Now, I am getting Wii error code 50300 when trying to connect. Is there any mistake while connecting the net? What does this mean?
Answered By 20 points N/A #321036
The error means that the internet setting is not correct for your Wii. It can be due to your network name, or your keys are some manual net settings.  They may also get changed during your last connection without your involvement. Try by setting a new connection using Access point using manual set up. If nothing supports you try by troubleshooting the internet connection tips in the manual video. As a last help call for the Nintendo service center.
