What Is Wii U Error Code 103?
Whenever I am attempting to link to the internet using my new Wii U, I am getting a Wii U error code 103-1601. The description goes as it can’t connect to the internet as more devices are using the same IP address. No one in the internet company can solve this problem. How can this be solved?
Answered By 0 points N/A #321047
The error can be due to fewer signals are the improper router. Sometimes you may forget to on the router, or the router name entered incorrectly. Check for these problems initially. You can restart the Wii U console and restart the router to solve the problem. While creating an internet connection, you should correct the wireless security type and key. You may also try by changing the channel. Don’t keep any metal objects near the router and keep it in a high place for better signals.
