jgulliver
10 points
Posted on - 07/15/2019
I tried to install NetFlix in my system, but it showed an error. With my friend’s suggestion, I thought to update my Wii System, but when I tried to install the update, it got a Wii update error code 32007 and stopped the update. What can I do now to install the update?
What Is Wii Update Error 32007?
This error occurs whenever you try to run an unofficial software in your Wii console during the update. Sometimes using satellite connection may also cause this error due to high latency. You should check for the internet speed before trying to install the update. Restart your modem or router may also show results sometime. Sometimes entering the DNS manually also helps to complete the download successfully. You may also try by changing the security type from one to another. If the Wii server is low, it may affect the update.
