What Is Windows 10 Driver_irql_not_less_or_equal MFEWFPK Sys Error?
I upgraded my c to windows in the morning. The pc has worked well for some time, and after installing some programs and restarting the pc, it showed some error like
driver_irql_not_less_or_equal MFEWFPK. I have upgraded my friends pc initially but never got this error. What can be the reason for this error?
Answered By 0 points N/A #321062
Most of the time, when trying to upgrade the windows, it shows blue screen errors. The error message above may say, to restart the system but the main problem is in MFEWFPK files. The system having McAfee as it’s antivirus has chances to get this error. You should uninstall the antivirus and delete the files using control. Sometimes third-party software also creates problems. So check for the corrupted files and restore them. Try by using a clean boot to the system.
