What Is Windows-10 Update Error 0x8024002e?
Whenever I attempt to modernize my windows 10, it shows me different types of errors. It shows me the update failed to install with windows-10 update error 0x8024002e when I am trying to download an update on windows server update service. What does this error mean? How can I solve this error?
Answered By 0 points N/A #321074
The error generally means that the windows update service is blocked. It can be because of malware, antivirus conflicts anything. Initially reboot your system and router and try to install. If it won’t work, then check for malware and try by turning off the antivirus. If not, see by scanning the files and restoring the corrupted one. Reset the windows update components and rename the software distribution and catroot2.  Always keep the windows update in automatic mode.
